Brief Description: Bottom of left wing painted white
Strait home from work, and I wiped the wing down once more to remove the days dust and then shot a light coat of white, I got a little carried away and forgot that the leading edge is going to be yellow so it does not need a coat white paint on it.... oh well brain fart. It’s not obvious in the photos but the coverage is light enough that in some spots you can just see through slightly, but that’s good because one more coat is all it will need. It should be interesting to see how many miserable insects land on it while it’s drying.
Outboard view, nice shine evident
Inboard view, insect count, one so far...
Rear view, three dead blow flies, its gotta be the white paint, at least I got them before they landed
