Brief Description: Bottom rear of right wing painted
This afternoon when I checked the wing, it was finally dry and safe to turn over, I again gave the bottom surface a light rub back with 600 grit wet and dry before wiping down with Prepsol and applying a single coat of paint. I am debating at present whether to apply another coat, I'll see once the paint has dried if it looks transparent in some spots, if not I can move onto spraying the leading edge. However that will have to wait until I get back from overseas with work. See ya in 3 weeks.The paint should really be dry by then.
