It's blowing a gale here today, but I was up early enough to be able to add 3 light coats of yellow to the rudder. Once this had gone touch dry, I relocated it onto the back of the fuselage and continued the line of the pinstripe from the fuselage. Its to soon yet to mask up and spray the rest of the Blue stripe as the paint is still a little soft and would not appreciate having masking tape applied, so perhaps I'll do this early next week. I also made up a support/doubler bracket for my aerial and bolted this onto the fuselage, the bracket has reduced the flexing in the fuselage skin and made the aerial installation quite solid. I got Anne-Marie to slide into the rear baggage area to tighten up the front set of screws on the aerial as this was the one spot that I could not reach plus I'm too heavy to slide in there.
