Eddie's Zodiac XL Project
Date:  6-7-2007
Number of Hours:  1.50
Brief Description:  Installing screws in wheel spats
Installing the screws, took as long as cutting the spats to fit the wheel last night, oh well, only the nut plates to install in the side bracket now. I re-bent the side brackets to fit the lower profile of the wheel spats. The brackets are made out of a really soft metal, which I suppose is good to stop damage from occurring if they get bumped. However on a low wing aircraft the bumping is probably unlikely. I can only hope that installing the right side spat will be easier because of the lower learning curve...
Screw into mounting top bracket
Screw into side mounting bracket
