Eddie's Zodiac XL Project
Date:  4-28-2007
Brief Description:  Installed step and fairings
Last night I etch primed the step and the insides of both the bottom fairing and the side fairings, and left them to dry over night. As the weather today was not suitiable for flying, I went up to Clive's place and wired his Ray Allen stick grip, servos and indicators. This ended being qutie a quick job, as Clive had aready run the wires from the servo and installed the wires in the stick, so all that remained was to connect everything together, turn on the power and ensue that it all moved in the correct direction. (And yes it did, just a little adjustment requried on the throws of the elevator servo).
When I got home, I installed the step, pop riveted it in place, followed by pop riveting the bottom fuselage fairing in place and then installing the side fairings on the step legs. I am trying to think of all the small jobs that need finishing before I start rubbing back the fuselage etc. in preparation for etch priming.
Left side step and fairings installed
Right side step and fairings installed
