Eddie's Zodiac XL Project
Date:  12-16-2006
Number of Hours:  3.00
Brief Description:  Installed control cables
After the fuel selector I decided to locate the nose wheel steering rods, and set up the correct position of the rudder pedals. I initally cable tied the rods to the top of the steering bolts and then climbed into the cock pit and adjusted the pedals for best fit. The rods where then marked and removed, cut down to the correct size and the rods ends fitted. The streeing rods connect directly to the rudder pedals with bolts, washers and nyloc nuts. With this done the next job was to swage one end of the supplied cable and attach it to the rudder pedal and then pull it through to the rudder where it was marked cut and swaged. The same was then done for the other side. The cable adjusters are located at the rudder end for easier access and allow you to take up any slack, it all comes together really well.
Nose wheel steering rods cut to size and installed
Rudder cables hooked up to the rudder pedals
Rudder cables hooked up to both sides of the rudder control horn
