Eddie's Zodiac XL Project
Zodiac 601 XL
Re-install undercarriage
Got more little bits done this evening after the excitement of the engines arrival.
After giving the gear channel another coat of primer I re-installed the undercarriage.
Left spat bracket drilled and bolted in place
Right spat bracket drilled and bolted in place
RV-7 Home
Zodiac 601 XL Home
2696
Ailerons
Baggage Tray
Brakes
Center Fuselage
Centre spar
Cowling
Fairing
Firewall
Flap assembly
Flight testing
Front Fuselage
FWF
Instrument panel
Left Wing
142
Mounting Horizontal
Rear turtle deck
Test flying
Undercarriage
Undercarridge
Upgrade
Upholstery
Weight and Balance
Wheels and brakes
554
