Eddie's Zodiac XL Project
Date:  6-3-2006
Number of Hours:  3.00
Brief Description:  Horizontal Formers and support brackets
There is a lot of work that goes into this rear section, I guess because it supports the horizontal stab and rudder, the cable access fairing comes pre-cut, but you need to cut the slot into it with a hole saw and then tidy it up, this is then installed under the top longerons and back drilled to the rear formers. Once this done some additional support L angles are installed, htese have already been pre-drilled and are then fitted in place and finally the top longerons are back drilled to the formers and side skins. Did I meantion there are more holes in the rear fuse then the wings...
This shot is meant to show that the rear of the fuse is square, i.e. top and bottom center lines match
Elevator cable exit bracket with slot cut and clamped in place
