Eddie's Zodiac XL Project
Date:  5-31-2006
Number of Hours:  2.50
Brief Description:  Rear fuselage sides
Tonight I started on the rear fuse side skins, these come pre-drilled from the factory and its just as well, because there are lots of holes. I started by marking and back drilling all the L angle stiffeners for both sets of side skins. Pretty tedious after the first few, but it dosn't take too long. I decided to do both sides at the same time, 14 angles marked, cut to size and back drilled.
As the parts come from Zenith, minus the tears in the paper
Marking out the L angle stiffeners
Close up, of side skin with L angle back drilled
