Eddie's Zodiac XL Project
Date:  5-21-2006
Brief Description:  Rear fusealage HT formers
WIth the bench shortened, I cleaned up yet again and got the bottom rear fuse parts out, took 30 minutes to find the 2 rear horizontal formers. In the end they where in the box in front of me that I managed to ignore because I had my drill and other bits on top of it. I made up the jig as suggested in the instructions and drilled the holes out to A5, coated with Cortec and poped the rivets, I can see no reason why this should wait to be done later. Also cut out the fairlead from the 1/8 Nylon 66, boy this stuff is hard to cut and work with. Anyway with these bits done I decided to call it quits for today.
Bottom of fusealage on the bench
Horizontal Tail former in jig to attach top angle
Both HT formers completed with angles and fairlead attached
