I used 1 days leave to take the day off work today and finish the Left wing. My father came over in the morning to help me rotate it so that I could fit the wing tip end plate and fiberglass tip. I had thought that I would be able to finish it in 1 day, but time again got the better of me. I have everything thing done except mounting the strobe and I also need to tidy up the bottom edge of the end plate. But at least its at a point where I can move it off the bench and into its cradle to finish these bits. I also pushed some bog in between the fiberglass tip and the wing skin as the fiberglass tip does not fit very well (had the same problem on the right wing, and a few people I have spoken with have had the same issue) and once mounted leaves a gap between the wing skin and fiberglass.
End plate mounted after much stuffing around
Fiberglass tip mounted and the leading edge tip filled with some bog
