Fabricated the Rear Throttle Linkage with a series of bends, cut the tubing to size, tapped both ends for 1/4"-28 thread. Ordered a clevis from A/S for the rear throttle linkage connection as it would be easier to use than a threaded bearing provided in the kit. Located and drilled the hole in the back half of the FWD throttle arm for the FWD linkage clevis. Located and drilled a hole for the linkage to pass thru the mid bulkhead just forward of the aft throttle.
