Brief Description: Quadrant Cable Relocation Part 1
After relocating my quadrant cable holes on the aft side of the gear tower last month, I decided it would be necessary to also relocate the holes on the forward side of the gear tower to make the need space for my cold air ducting. This is something I overlooked when I decided to run my air duct up thru my forward baggage compartment floor. This would also allow a straighter run for my quadrant cables thru the gear tower. I disconnected the quadrant cable and pulled them thru the gear tower. I crawled up inder the baggage compartment and took some measurements to relocate the cable holes on the front side of the gear tower and also size a doubler that I would have to fabricate. Since I would be drilling all new holes in the gear tower I didnt want to weaken the structural integrity of it. I cut out a 3 x 4" piece of .032 to create the doulbler. I located the cable and EMS pass thru holes as well as the rivet holes to secure it in place and the drilled to size.
