Brief Description: Cable Mounting Bracket Fabrication Part 4
Located and drilled the mount holes for the throttle cable mount on the bottom of the engine.Final fit and trim of the quadrant cable mount. Clamped in place with cables installed the drilled the final mounting holes in the longeron. Cleaned up the holes and then scotchbright the quadrant support bracket and the throttle cable mount bracket. Primed and the final paint. High temp enamel paint for the throttle cable bracket on the engine and matching interior paint on the quadrant bracket. Reinstalled the quadrant cable support bracket and throttle cable bracket. Reinstalled the prop, mixture and throttle cables and readjusted for the last time.
