Now for lots of little details. Pic 1 shows that I'm setting up the heater box and have found the extension to operate my Andair on/off main fuel valve is too close to the box. See the purple rod almost touching the box?
Everything is tight here so that I retain the maximum possible space for the passenger.
This was an easy fix.I lopped off the corner then later floxed on the flat piece of glass you see in pic 2 and then a tidy up.
Oh you might notice I now have a pipe inlet opposite where the eyball hole is on the back seat. This was about three cure cycles over a day or so. I had to make the glass shape from my pipe form, clean it up, flox it in place, clean up. You know the routine, right?
