Daves Web Site
Date:  8-8-2017
Number of Hours:  4.00
Manual Reference:  no ref
Brief Description:  Oil Heater 32 Adding the Passenger heat outlet
After making more pipe.... Really I had a long piece made with the pipe form and I've been cutting lengths off as I go. I only needed two long bits and I made several fittings from these.
Pic 1 shows I'm ready to fit the passenger or PAX outlet. You can see I don't need the extra plastic on the valve. Pic 2 and I have ground it all off. Less weight added you might say. You can also see how well the valve closes one side completely.
Pic 3 and I've floxed it in place. Glass to this black plastic works really well.
Looks like excess material?
More weight reduction
Floxed in place
Floxed in place
