Brief Description: Fuel System Getting those ducks in a row 4
Pic 1 shows a bit more work has been done. After the base click bonds were in I made some floating nut plates up and inbedded them in the sump wall. Again using a stick on the assembly and release tape. I then went ahead and did another click bond thing for the adel clamp what will hold the post pump filter. A bit of time went into pic 1.
Pics 2 and 3 show you the assembly in place. I have gone to enormous trouble with a lot of thought and time to make this work. It just didn't seem to be possible to make these items fit in here at first. I had to source fittings I didn't even know exisited. Now its done, it looks easy, simple and why was it a problem in the first place?
