Daves Web Site
Date:  7-26-2017
Number of Hours:  1.00
Manual Reference:  no ref
Brief Description:  Oil Heater 19 Parts and Planning
Again this was many hours, overseas orders and a lot of thinking.
Pic 1 shows the heat exchanger in its case, the Y valve and an RV alternate air box that I thought I could modify into an open or closed shut off valve. Pic 2 is another look at the box before I hacked it up and a simple push pull cable that would later operate it.
Pic 3 gives an idea of where things will go. That RV box needs to be right in the corner. I still want room for cables and wires on that side. I need an exit for that straps that will hold the ferry tank and inboard of the radiator there needs to be the rod from the on-off valve. Everything that has air also needs a straight path where possible. Tricky stuff.
Parts
Parts
More parts
More parts
Placement planning
Placement planning
