Daves Web Site
Date:  7-25-2017
Number of Hours:  6.00
Manual Reference:  16-7
Brief Description:  Part install of Brake lines
As I was working on fuel lines it seemed a good idea to get the brake lines in place now. I have SS lines, no plastic. Its something I want to install without any concerns.
I ran the lines both sides and then use micro and 1 ply of BID to secure them to the fuselage sides. They are just exiting at both ends for now. It does mean I can get on with putting the fuel system in place.
I had to add some foam fillets in the rear exit area so the lines would sit without strain. I really would like to do it all again a be a bit tidier. The micro on the fuselage sides doesn't look pretty. No one will see it except me, which is not the point.
Secured with micro and BID
Rear exit line supports
Line support glassed
