Brief Description: Oil Heater 12 Securing the shroud
Before the shroud went on I had to work out a way to get the hot air to both feet. I put a separator onto the top of the wheel box front section as you see in pic 1. Next up were some vents in the shroud or openings if you like.
Pic 2 was the quite large job of securing the shroud. I'll save you all the pics. In short, I floxed it into position with the clicos still in place. After cure I removed them and then added some BID tapes to tidy up. There is a finished pic in a couple of logs.
Pic 3 is my hi tech sliding trap door control. Just a bit of AN hardware and a slot. Works a treat.
