Daves Web Site
Date:  5-22-2017
Manual Reference:  no ref
Brief Description:  Flox PVC to Aluminium Test
I needed to make a viewing port in my common sump by bonding 6mm PVC to 2024 T3 aluminium.
Does it stick? I make up a test piece as you see in pic 1. I am using EZ epoxy. The PVC is 6mm thick, I routed a 3mm step into it and primed with a comercial PVC primer which is really MEK and acetone combined. I roughened the aluminium surface with 40 grit sandpaper and cleaned with acetone.
I painted the surfaces with pure epoxy and then mixed up flox. I bonded the two surfaces, clamped them and left for two days to cure.
Pic 2 shows that I have put the joined pices in a vice and hooked a weight measure device on the PVC and applied a shear force to try and break the bond at the weakest point.
At between 20 and 25lbs I was bending the .080" 2024 and still the join held! I measured up to 26.5lbs which took a lot of fulling force. Somewhere between this and 30lbs the join failed.
That is seriouisly strong! Pic 3 shows that the join failed cleanly at the glue line. I also noted that a bit of glue that squeezed out onto unsanded aluminium and unprimed PVC failed very cleanly suggesting how important prepping the surfaces is.
Test Piece
Test Piece
Shear 26.5lbs OK
Shear 26.5lbs OK
Failed
Failed
