I've been playing with this since October last year as a little side job and its finally done. These are the side tie downs for the 250 liter rear ferry tank. Yes did I mention this is for crossing the Pacific Ocean? Yeap I have plans for this plane....
I've simply added two more 'seat belt' hard points per plans to hold the ferry tank on the sides when its in use. When I have this tank in the back I'll use the existing passenger belt points and the two new ones I've now added for the front. Pretty simple. Four side tie down points. I'll also need front and rear points which will come further on in the build.
