Daves Web Site
Date:  9-28-2015
Number of Hours:  10.00
Manual Reference:  HP Rudder R1
Brief Description:  Setting up Rudder hinges
Using my angle iron I finally got things aligned properly. This really took a while and I ended up using lots of clothes pegs, also hot glued, to keep things steady. After all I do have to have it secure enough to drill.
Pic 2 shows after some hours the careful cutouts for the hinges. Pic 3 and after some research and thought I decided on where the rivets were going and how many. Confirming the alignment many times I drilled out for the smallest cleco size I had and called it a day.
Hot glued
Hot glued
Recess cuts
Recess cuts
Finally holes
Finally holes
