Daves Web Site
Date:  6-6-2015
Number of Hours:  10.00
Manual Reference:  19-18
Brief Description:  Wing Bolt pilot holes
I rechecked all the levels again today and it took a few of hours. I think I have it now so time to secure the wings for drilling.
Given I'll be pushing pretty hard with the drill, in a positive way, I made a couple of push back jigs as you see in pic 1. Now things are leveled I do not want movement. I also used bondo per plans and a few mixing sticks as shown in Pic 2.
To keep the drill level I'd made up as set of aluminium guides with 1/4" holes and bondoed them in place so that the long 1/4" drill was level and square from the outside to correspond with the pre drilled spar holes.
Once happy I got to it and the six 1/4" holes all the way through were done. The relief in seeing them come out at the correct place on the wing side was significant. I know I have it all lined up as best I can. It was still good to see the drill bit all the way through and somewhere near the center of the hardpoints.
Wing push back
Wing push back
Everything level and secured
Drill wing pilot holes
