Daves Web Site
Date:  1-25-2014
Number of Hours:  10.00
Manual Reference:  19-4
Brief Description:  Wing Core Storage Shelves
While this is not technically a plans item I needed some special shelving.
The 4 wing pieces are together ready for more work. Meanwhile I've decided to move on with the CS spar and then check the wing core size and alignment before going further. This meant those cores were not only in the way but subject to damage with the slightest touch.
Completed wings are stored leading edge down so I needed some shelves both out of the way, on a long enough wall and able to hold the wings and even the CS Spar.
As you can see in the third pic... job done. I've covered the cores in plastic bags to prevent possible UV damage.
All good and back to working on the CS Spar.
Wing Cores
Wing Cores
New Brackets
New Brackets
Wings wrapped and stowed
