Daves Web Site
Date:  10-16-2013
Number of Hours:  10.00
Manual Reference:  13-7
Brief Description:  Pivot Block nutplates
These are the nutplates need for the rudder pedal pivot blocks.
Pretty easy to make. Off course my first ones used domed rivets instead of countersunk. Oh well easy fix...
I cut to size per plans plus 0.1" I just wanted a bit more edge to the sides of the K1000 nutplates. As you can see it worked out OK and fun to make after struggling with the spar for months.
I cut out the back of the foam blocks ready for the plates to be glued in place.
2024 T6 0.063
2024 T6 0.063"
Alodined
Alodined
250H foam blocks
250H foam blocks
