Daves Web Site
Date:  6-28-2013
Number of Hours:  10.00
Manual Reference:  9-3
Brief Description:  Axle Pad template guide1
The axles need to be mounted with a 4 degree camber and a 1/4 degree toe in. Not a simple task to set up.
My idea was to position a board at the correct camber/toe in and then just use a router to make a flat pad at those two angles in the one go.
First up was a simple base for the pad to ease the initial set up. Next task was to calibrate the lasers on this board. If I just screwed them to the board, how do I know if the beam is parallel or not? This was done by measuing the height of the laser at close and far range. They should be the same height above a straight edge right? Well they were not! ...but a few shims and some time and I had my papallel pointing device.
Next was to mount it on the leg in the right position.
Template guide
Template guide
Laser calibration
Laser calibration
Laser on leg
Laser on leg
