So begins setting up the Wilhelson Nose lift. A linear actuator instead of the wind up gear and its associated electronics.
I spent a day or so on the wiring trying to bench test the gear. It seemed to have intermittent faults which after more days I traced to No2 connection in the first molex plug and a jumper lead in the second molex fitting. I bipassed one of the plugs and hard wired it. Testing resumed.
After some thought I floxed in NG3/4 as in pic 3 in the plans position which is quite exact and so I thought important to follow. (wrong again)
