Daves Web Site
Date:  3-7-2013
Number of Hours:  10.00
Manual Reference:  9-2
Brief Description:  Outer Gear Tab Layup
After the big clean up I prepared all the glass for the outside tab layup. All the plywood was removed and the spaces cleaned out carefully. I first layed flox into the join to allow a smooth transition for the glass.
The 18 ply UND 12" long layup on the first side was straight forward but this time I trimmed them and constantly used my fingers to get the air out and keep the fibres straight.
The BID I had in layers of three and this was a lot easier to apply than one at a time. I was watchful for slippage and air and pretty much used my fingers rather than squeegee's or brushes.
I clampd very carefully as the whole shooting match will slide around when you put pressure on and I needed to ensure we remained without airgaps to the gearleg. I then did the second side and it was a lot easier overall than the first lot of layups a week or so ago.
Now its a matter of letting it get hard, drilling out the holes, a bit of a careful trim and then setting it all up again on the fuselage. Still more fun to come.
First tabs cleaned
First tabs cleaned
One side layed up
One side layed up
Clamped for the cure
