Daves Web Site
Date:  2-3-2013
Number of Hours:  10.00
Manual Reference:  9-1
Brief Description:  Gear Jigging Blocks
Using the plywood left over from the firewall, this step is just making 4 jigging blocks.
I did this very carefully and it was probably overkill yet all a part of trying to keep the build standard as high as I can.
The blocks fit two on each gear support as in the third pic. I had to open the holes just a touch so they would slide over the knerled tube.
Blocks match drilled
Trimmed per Plans
Trimmed per Plans
Jigging blocks on gear
