Daves Web Site
Date:  1-19-2013
Number of Hours:  10.00
Manual Reference:  9-1
Brief Description:  Micro landing brake edges2
Again over several days. I worked out that 7 plys of this thin grey tape would equal some filler, primer and paint. I then carefully covered the brake with 7 layers of tape for another try at using micro to get great edges.
I used weights to ensure it was all sitting a flush to the fuselage as possible while it cured.
It turned out that a small amount of micro made it past the release film and it took about 6 hours to get the brake unstuck without damage. Note to self...more release material next time. A little scary.
You can see in the last pic some cleanup is needed. Its easy to remove the 3 screws holding the brake to do the work.
7 layers of grey duct tape
Weight for cure
Weight for cure
Ready for a tidy up
Ready for a tidy up
