Daves Web Site
Date:  12-30-2012
Number of Hours:  10.00
Manual Reference:  8-1, 8-2
Brief Description:  Glass inside of rollover belt support
The 'inside of the rollover is glassed with just one ply of BID. You can see this in the first pic. I have peel plyed it and some timber residue is in the pic that comes off with the peel ply. I was keen on getting this straight so put some weights on the layup as it cured.
The second pic shows the bare inside roughly timmed. There is a 12 ply reinforcement pad that is to be layed up over the wooden insert from the other side. I first made up the 12 plys separately as in pic 2. This seems a lot neater than the plans method.
I then cut out slightly oversized pieces of this glass and carefully routed down to the timber inset as in pic 3. It was then easy to flox these in place.
Outside of rollover
Outside of rollover
Glassed Inside of rollover
Hardpoint inlays
Hardpoint inlays
