Daves Web Site
Date:  10-14-2012
Number of Hours:  10.00
Manual Reference:  13-5
Brief Description:  NG30 more prep
With the insides layed up this prep is for the hard points inlayed from the outside.
I drilled pilot holes in the five locations after ensuring both sides were the same size by taping them together and trimming. The hard points I cut out with a router and a metal cutting bit. Then a quick trim with hand tools.
Using the cut pieces as a template and a drill bit through the centres to position them, I marked the holes and the oblong. Then I VERY carfully set the router to the exact depth of where the glass starts on the NG30 and routed out the holes like making a jigsaw puzzle piece. I just carefully routed to the lines and ended up with tight fits for the pieces.
I marked lines on the circles so I could get them back in the same place and orientation.
Then I cut out 8 pieces of glass for the 4 ply layups. I used 45 degrees bias but the plns say anything is OK. This always takes a while and I used the taping technique to keep the weave pretty straight when the pieces are picked up. ...probably over kill I know.
Match drilling
Match drilling
Hard points
Hard points
Inlay and glass Prep
