Daves Web Site
Date:  5-27-2012
Number of Hours:  10.00
Manual Reference:  5-3
Brief Description:  Gear Pad Layup Part 2
This step requires 15 ply of bid in 4 areas. I first preped the 60 pieces of glass required.
I had been told they can be cut to exact size during the layup but after one try I accepted that I just needed to lay up with no air and, correct fibre direction and correct glass/resin ratio. How to cut wet glass to exact sizes I'm yet to learn.
It was a very big job and next time would be better in two goes. I worked all day and into the night. The room was at the correct temperature and I needed a separte batch for each area. Even then two batches each may be better next time as it gives an easier work time.
Glass Prep
Glass Prep
Release Tape
Release Tape
Weight for cure
Weight for cure
