Brief Description: Restarted the VS after getting new parts
Restarted the VS now that I have the repalcement parts and have done all with the rudder I can until it's primed. Used the drill press to match drill the spar caps to the spar. If I had to do it over (I don't) I would do this by hand as I'm still not real thrilled with how this process turned out - a few less than perfrctly circular holes. Got the spar caps, doubler, and hinge brackets final dirlled to the spar. Also final drilled the top hinge doubler to the bracket and spar.
