Brief Description: Finish sanding port wing/strake, cowling & landing
Over the last week burn through endless 240g sanding pads. I got some more supplies, and tried initial sanding with 80g and that just works brilliantly. So I sand through the high spots with the 80g, then finish off with the 240g. 240g only on the leading edges. Anywhere tricky I use 240g wet sanding, everywhere else with the festool dry.
