Brief Description: Epoxy wipe port wing/strake, gear legs & cowlings
WIPE with raw epoxy the port wing upper surface, repair bits on the lower, winglet, port strake top, both main landing gear upper surfaces, the remainder of the fixed turtleback and both cowlings. 5 coats that took about 2 hours each, with tiny break between.
