Brief Description: Nose weight compartment and various fettling
Floxed mounting hinge half back onto pilot's headrest and rivetted with BSQ-44. 5-min floxed a support at the back, and 1 x BID either side.
Cut tube in half and easily extracted form. Yay!
Used leftover resin to cover some exposed foam in the luggage compartments. Have started putting outstanding jobs up on a whiteboard and it is working well.
Finished trimming rear seat cabin vents.
Back-filled some chips in the edges of the canard cover.
Drilled some exploratory holes through F-0 and contemplated how to fit the tubes. Might work.
Topped up the flox, then 1 x BID over the nose weight door nutplate.
Spill acetone over the rough log, destroying the resin record for this work...
Particularly slack at picture taking at the moment
