ROBERT'S WEB SITE
Date:  7-22-2018
Number of Hours:  3.00
Brief Description:  First Engine Start!!!
First engine start - all temps and pressures normal. Oil pressure (76), oil temperature (77), fuel pressure, fuel flow, CHTs and EGTs, Volts/Amps all indicating as expected and within normal parameters. Idle a little low at 630 RPM. Idle Mixture very rich - about a 150 rpm increase. Will adjust that down in a later session, but want to run the engine a little more first. Did a very brief full power run up and it was starting to exceed 2700, so may need to adjust the stop on the prop hub itself. Will wait and shoot it with an optical tachometer to be sure.
