ROBERT'S WEB SITE
Date:  2-8-2018
Number of Hours:  8.00
Brief Description:  Torqued Exhaust. Removed preservative oil/added o
Torqued Exhaust 180 inch lbs. Removed preservative oil per Lycoming procedure - removing bottom plugs and rotating crank. Added 7 quarts of Aeroshell 100 (50 W mineral oil good for 60F and above - as I will be flying in the spring/summer initially. Red Cube install and fabrication of all servo lines (303-4 for servo to red cube and red cube out to flow divider/spider). All hoses firesleeved.
