Brief Description: Exhaust mocked up and EGTs drilled. Throttle brac
Exhaust mocked up and EGTs drilled. Throttle bracket reversed. As others have reported this is way too close to the exhaust for comfort. It will quickly ruin the throttle cable. As others have done, reversed the orientation of the bracket so it is on the RIGHT side (co-pilot side) offset. This aligns far better with the exhaust orientation. You just reverse everything on the rod end and it all works out great. You need the 1" offset Z arm, but that came stock wtih my IO-360-M1B
