ROBERT'S WEB SITE
Date:  1-25-2018
Number of Hours:  1.00
Brief Description:  Prop governor installed and oil pressure restricto
Prop governor installed and oil pressure restrictor installed. Notice that the governor pad does not have holes on the RIGHT. I checked with the PCU 5000X service team and confirmed that this is ok. It is the LEFT most lower port and the smiley port that must have flow. The right port is not needed or used. All good. This will need to come back off anyway as that left lower stud was not properly installed by the factory - it is about 3/16" farther out than the other three.
