Brief Description: Longeron twist tweaking and mounted firewall
Longeron twist tweaking and mounted firewall. Clamped firewall assembly to longerons after adjusting the tw.ist ever so slightly to match the weldments. Fitted F772 forward bottom skin and firewall. Drilled initial 2 holes from F772 into the firewall angle (bottom) to fix firewall position
