Darrel's Kitfox - SS7
DEW2
Contour rib profil
Contoured rib profile and more work on tip
Sanded out the "hump" set up by the leading edge of the main ribs using the template that came in the kit.
Began filling in the low spots on the wing (i.e., gap between fuel tank and spar and leading edge and spar) with Super Fill.
While waiting for the first mix to set up, worked a bit more on fitting the wing tip on the right wing.
The hump
After sanding
Super FIll in action
H-5 Home
DEW2 Home
3012
Basic Kit
211
Fabric cover
82
293
Final assembly
701
Inspection
Kitfox Avionics
Kitfox tooling
Kitfox Undercarriage
Kitfox wings
Lighting
88
Modifications
Paint System
87
335
Tooling
Tooling
Undercarriage
