What are the chances of being about .25" out for fitting the exit hoses from the Heat Exchanger? Pretty high possibility hahaha.
I elected to go -10 hoses here to get a better oil flow. I'm using SpeedFlow 101-10 and a fitting that goes from -6 to -10 on the radiator. It was just a little above the armrest core but not above the top.
My fix was to cut some foam away, make a concave glass insert, clean it all up as you see in pic 2. Pic 3 and we have a fit.
A small job but typical for this part of my build.
