Having done the pins a while ago time for the tabs. I've just made them per plans. Some high density foam 5mt glued on. OK I did tidy up the set glue before glassing them.
I did the two sides in separate cures. One had a bubble in it so of course I ground it off and did it again. After cure I trimmed the edges as you'd expect.
