Brief Description: Joining FC1 to the LHS wing cores
The process is similar to the RHS wing. Line it all up and find there is a gap in the shape of a small wedge.
Sand the wedge out within about 1mm. Then glue the cores together all nicely lined up.
I hope I have it close to correct. I will make the spar troughs a fraction deep and hopefully minimise the amount of filler later required to line it all up.
May this effort pay off! At least I understand a little about how to line it up when its time to drill out the bolt holes after the wings and spar are built.
