The first pic is just a reminder of where the hard points are on the spar relative to the wing FC1 core. Thought I'd better stick in a pic with a ruler somewhere! I hope to maintain those lines despite sanding and so on along the way in case its useful later.
Pic 2 shows the LH upper wing cores going together. I used a bit of the packing foam to help the clamping.
Now I am ready to lay out the floor again, but for the LH wing so I can get it all lined up and find where FC1 needs to go. Its a bit of a proceedure but good to do it now while the benches are moved and its fresh in my mind.
I am thinking about where the wing cores are going to be stored!
