Wendells RV-6A
Date:  2-1-2024
Number of Hours:  1.00
Manual Reference:  Seal Passthroughs
Brief Description:  Seal Wiring Passthrough Openings
I believe I am through sending wires and antennas, etc through the firewall on each side, so it was time to seal those openings. The thru-firewall fittings had enough neck on them to allow two hose clamps. I wrapped the wiring in silicon fusing tape around an inner orange heat wrap. Then as I slowily moved it into position, I locked it down with the two hose clamps around an outer orange heat wrap. Its solid and it sealed up nicely.
Hope there's no need for another wire.:):)
