Brief Description: F-631 C/D Final Drilled for AN4 bolts #2
Roll bar ready to secure to those mounting angles, now that they have been drilled for the AN4 bolts. To get the roll bar to end at the front of the F605 bulkhead top, you need to set the mounting angles back about 1/8 inch. They reside inside the roll bar so with the tilt and the thickness of the roll bar skin, thats the way it goes. The tip up canopy frame will match this tiltback with a 1/4 inch gap between it and the roll bar. More fun down the road. I read frustrating build sites dealing with the canopy frame. I trust I will not face all that:):):).
Wrench fits both bolt heads fine.The keeper rivets are AN470 AD3-7 squeezed into a countersink below.
Same success. Note keeper rivets were AN426AD3-7 cut down from longer ones. Ran out of these.
Tilt back is 2 7/8 from vertical. Height is 17 7/8. Right on.
